Can you change channel 3 switch on GT5?
spookyseven
Not where I belong.
Is it possible to mod the channel 3 on a FlySky GT5 to a 3 position switch? I'd like to use channel 3 for a 3 position winch controller but it doesn't work on this radio since channel 3 is only a 2 position switch. If it is possible to mod the radio to a 3 position switch, would it have a problem with winch drift or can you just adjust the trim when setting up the winch controller?
I have done that with analog input radios like the TQi. I believe you need to change the software on the FlySky GT5 for that switch to be changed.
There is a work-around though. Hey'OK sells a nifty device that allows a channel with only two positions to control something that requires three positions, like a winch.
Yes, but there isn't a way to assign that button to channel 3 when using a 3 channel receiver. I was hoping I could just change the button for channel 3 to a 3 position switch but it's soldered onto a board. I'm not sure what it takes to change a button when it's surface mounted. It would be nice if it was possible to remap the buttons, but it's not an option from the factory and I don't think anyone makes a hack to do it.
