DX5c Losing reverse, need help??
KWicker81
US
I am running a Mamba x and 2850 slate, Spectrum Dx5c RX TX, Savox 1290sg servo, and a RC4WD Winch and wired controller.
After running for a little while I will lose reverse at the Radio. When I switch to monitor the radio output ( on the spektrum radio) it shows that reverse is reading at -4 to -6, essentially no reverse. To correct I have to reset the model and re-bind, then all works correctly again. I think the RC4WD wired controller is causing interference?!?!?!?
What button are you using to control your winch? I had a problem where the button i assigned to use with my winch was also set for brake adjust from the factory. It would make me lose reverse in my situation. I have seen a few other people with this issue to.
