New to the forums and Rockcrawlers for that matter, so hello everyone.
I have been looking around and noticed a huge amount of hard-body custom work vs other types of RC cars.
Also noting that many built cages with metal and so on, I decided to share with you all a painting solution that might be the best thing for you crawler guys.
The paint is called Duracoat.
Its a two part paint that is far superior to spray and automotive paints out there intended for use as a weapon coating/paint.
I have much experience using it, as I do a lot of custom work with real guns, airsoft and paintball included.
The stuff is simply amazing tough and is almost impossible to wear out, through, or off.
It can be bought cheaply as one of the best parts for its performance value.
It is applied with an airbrush as a very thin layer, yet is very easy to work with like many other paints.
It can be baked on metal parts or left to dry like anything else on any surface.
Naturally on things like chrome or slick alloys, you will want to rough it up a bit before application with a fine sand paper, just enough to give the surface "tooth" to grab and hold the paint.
There many color choices out now, and if you want something in-particular that isn't offered, its just as easy to mix as ordinary paint to get the desired color.
Just to exemplify the durability of this stuff, consider this.
Its is way stronger than powder-coating and as good as hard coat anodizing.
Its used on machine guns that can reach a couple thousand degrees at the barrels, will indefinitely seal all working parts and has been tested in salt water for very long periods of time proving once its on its not coming off and will protect everything. The only way to remove it is with a sand blaster.
There has also been a new additive that is now in the paint that puts a type of synthetic such as silicone in the mix to help self lubricate moving parts, much as delrin plastics are made.
There are many other cool things such as phosphorus impregnated paint that glows in the dark for years, pearls and now a couple metallics.
Just seems to me like some of you guys might find this stuff very beneficial considering all the sliding and grinding in this genre of RC, and just to better protect your gear.
Anyhow here are a couple of pics of things I have painted with the stuff and a link to the site where it can be had.
http://www.lauerweaponry.com/
