OK this is my first build thread, or should I call it a built thread.
The rig was finished just before worlds. with only 4 or 5 packs thru it. I was very impressed with a Fifth place finish at worlds.
I will try to get as much info in the thread and as quick as possible. Work has been impossible since returning from Logandale.
Here's the finished product.
So once I convinced Tobias to let go of one of his babies I started building components. First up was the shocks. I cut down the shafts to 35mm and re-threaded them.
The shock bodies were reduced by 10mm
Assembled using the Axial machined pistons and the lightest oil I had 20wt. RCBros spring retainer with pink Losi Mini-T front springs.
So I have to run now but I'll try and get a second post tonight "thumbsup"
Force5
Force5
