Dok's "AK49" Crawler
New to the RC world. I'm a professional wrench turner that has built and wheeled real life crawlers as a hobby. Small stuff on 42" tires. I bought me and my daughter a cheap RC car from Walmart to play with, and I burnt the motor in the first 10 minutes. After that, I thought there must be a better way... and discovered the RC crawler world. I bought an Axial Bomber last weekend, and have started building it. I'm building it like I did my fullsize rig, geared dirt nasty low with a lot of torque.
Out of the box, reverse didn't work. Then the ESC literally almost caught on fire in the first 10 minutes, but I disconnected the battery in time. I tore apart the AE-5 and it looked like the positive battery cable solder melted and caused a short to negative. Good thing I disconnected the battery so quickly.
I replaced the ESC with a Holmes Hobbies Torquemaster, programmed it with castle link, put in an Axial 55 turn motor, Axial 11 tooth pinion, and Axial aluminum servo horn. I have a BEC, I'm waiting on a Savox 1210 servo and Vanquish steering links. I also have some slipper pads on the way, so I can install my Axial 68T spur gear.
The way I usually build anything, is run the hell out of it and upgrade whatever breaks next. As far as preemptive upgrades go I'll regear the axles, beef up the links, and get some taller tires. I'd like more belly clearance, and less bendy plastic components. The stock driveshafts also annoy me with how sloppy they are.
So far it crawls nice and slow, with a decent amount of power on tap for wheel speed when I need it.
Here it is pretty much stock. I'll take more pictures as things happen.
