I do not know if "RX/Servos Power Booster" is the correct name but hope you understand.
(They told me on posts below they are called Glitch-Busters, thank you MikemcE)
Now it is possible to use the battery that feeds the motor, to feed as well the RX and servos because there is already lots of high voltage options on RX and Servos, and that is what I plan to do on my Super
In other words I am not using a BEC, I am just connecting the battery to the receiver.
But there is an issue on electric RC cars, acrobatic electric planes and 3D electric helicopters, that there is big current surges that can droop the voltage that is received by the RX system and that can cause problems like loose of control or servos power loose and glitches.
Sometimes even with a BEC this device is need.
So this is a cheap and simple device that fixes that possible issues.
It is just a electrolytic condenser/s that plugs in any of the receiver free channels ports.
The cost of this kind of DIY devices: connector + condenser/s heat-shrink tubes is less than 6€
Notes:
- This is a quite small unit (3300uF) but enough for my case.
- Depending on the the size and use it should be smaller or bigger. The bigger the better.
- To make it bigger it is possible to connect various condensers in parallel.
- This condensers are polarity sensitive so make sure to check polarity.
- This condensers are voltage rated so use one/s always above the voltage you plan to use (i.e. I plan to use 2S or 3S battery so I choose 16V)
- The cable lead should be as short as posible.
Notes:
