Direct power servos getting killed by small 4s lipo
JohnRobHolmes
owner, Holmes Hobbies LLC
Moderator
Volt up! Gear down!
This is an issue that has been ongoing for a few years and some of yall may be aware of it. In a nutshell, packs smaller than about 600mah are a common denominator to "infantile death" or other very untimely failures of many direct power servos. Some models of 3bros dont get killed because they have higher voltage ratings, but finding good 35v driver circuits is tough. There are a good bit of 25v components and a huge plethora of 16v from the origional 8.4v servo designs. Pretty much all 4s direct power servos are 25v drivers.
So what is happening? In a nutshell, whenever a servo or motor stops suddenly, there is a burst of back EMF. Amperage doesnt want to stop, so the voltage starts to climb. In a "normal" system the battery shunts the current and recharges just a little, and the voltage doesn't spike above pack voltage. But when the pack is so small that the ESR is very high, that amperage has nowhere to go and the voltage can climb very high. With a normal pack ive never seen above 20v. With tiny packs ive seen close to 30v.
I have addressed this issue already with TVS and zener diodes to absorb the spikes, so why did it come back? It appears to be two fold.
-- First is the servos and motor systems getting more and more power dense. As the resistance of the systems get lower, the spikes get faster and go higher. So a zener has to work harder, and might not be fast enough. You may see people blaming this on "drone ESCS" but the problem happens with all types of systems. Its just that everybody running the small packs are also running am32 escs right now.
--The second issue is that battery sizes have gotten smaller and smaller,. And even though the discharge rates are very high, the ESR is still too high to absorb the spikes. Older batteries also go up in ESR which makes the issue worse.
So what is the solution right now ? Either larger batteries, running a BEC powered servo, or adding a lot of capacitance in parallel with zeners or TVS diodes. We are talking 1000uf with an ESR of 50mohm or less. About 10 grams of components, the same volume and weight as a BEC. And another 1000uf will destroy your plugs, its a LOT of inrush current.
Im looking for 35v drivers, but in the mean time the solution is going to be either going back to BEC units or installing a snubber thats about the size of a BEC. I would cram it into the servo if I could, lol! But not enough room, no way no how.
So thats whats happening in the direct servo world these days
I have been following this as I use small 4s packs, direct power servos, and AM32 ESCs in a couple of my comp trucks. Based on what I've experienced, I dont think that is the only cause of the failures.
A friend of mine had one of the 650LPs die on course last Saturday and he was running a Hobbywing Mini Fusion with 1800mah 3s pack. We were going over his setup right before the comp and he said he had switched to that specifically to avoid the servo failures. I had one of them die on the bench (end points were set correctly and the servo had been through a couple comps). I only had the truck on to respool my winch IIRC so I didnt even drive it that time. I've also had a couple RS700V2s crap out on me. I changed ESCs to see if that was the cause. Come to think of it, all 3 of those failed with a Rhino 80A.
Currently almost all my servos are direct power but if I have more failures, I may start switching back to BEC powered.
How much larger of a battery would be the safe zone?
My smallest 4s packs are 850mah but I haven't used them with a direct power servo yet.
around the 600mah range is where it seems safe, but it depends on pack quality and age as well. 850mah seems very safe.
There are certainly some failures not caused by the little 4s, the little 4s is a problem all to itself.
4 pole servos can also burst so much on deceleration that it overwhelms the regen of the battery. I havent done any scopes yet but Im betting we could see 25 to 30v bursts there too, no ESC involved at all.
I also have concerns about some of the internal BEC units on the ESCS, with the huge voltage spikes the BEC is also going nuts and killing the brain of the servo. Ive killed some RX this way already, when the BEC went unstable. Ive had certain trucks that would reboot fully on decel because the BEC was too unstable to handle any voltage spikes.
The attempted power density of products these days is generally causing issues, lol!
Having to run a BEC or any other sizable, extremal component, is a huge step backwards
I would hope that would be plenty big.
It is a step backwards but if people keep insisting on running these teeny packs we have to have capacity elsewhere to snub the spikes. ESCs are fine because 35v components are super common. But in the servo world the drivers are mostly 25v and lower still.
So either people run a normal sized battery or we need extra components to make up for the problems of running a small battery.
Seems like it's time for a disclaimer on the servo product page and another product offering for those that don't want to heed the warning. I typically run 3S 2200mAh or larger so I'm good.
Just to clear my noob confusion, are you guys talking about all servos or just big servos or what?
I have a one twenty four truck so I only use small batteries and I would hate to fry my ninety nine servo.
Only Holmes Hobbies branded servos that are directly powered by the battery.
It's not only holmes servos. Other 4s direct powered servos too. NSDRC has supposedly done some upgrades to the newest batch of rs700v2 to fix the problem.
Interesting. He had that optional diode you needed to use, but now he's saying that's not enough?
After my lp 650hv failed, i put the rs700v2 back on my c1 with a zener diode and so far so good.
"Mark Superior" replied to one of my posts on a Facebook group saying that there was something different in this new batch of servos that's coming out. I think he said there are 30 of them out there that have been running for a while with no failures on a variety of different escs. I didnt ask what components were different.
The diode was fine until batteries got smaller and servos got more powerful. I honestly think there are more issues stemming from 4p servos than the ESC and motor now. more diodes isn't going to solve it either. We need capacitance to catch the spike before the diode starts conducting, and that capacitance can't fit into the servo case. No physical way to cram 10lb into a 1lb bag.
Most of us who are running direct powered servos do that so we dont need to add the extra wiring (and weight) of a BEC or find a spot to cram the thing. If we have to add something as large and heavy as a BEC to ensure reliability, that eliminates that advantage. May as well go back to a conventional BEC powered servo and get more consistent performance through the entire battery.
I was using 300mah 4s from RDQ. Killed 2 servos the same way. They would not center anymore and were very weak. Back to my 4s 650mah pack.
Interesting discussion. I have been running 4S 650mAh batteries with my Holmes SHV500LP servo and Rhino 40A ESC since September and haven't had any issues yet knock on wood.
@JohnRobHolmes When you say the voltage spikes are caused by the servo stopping suddenly, are you talking about letting the servo snap back to center with the controller, intentionally shaking the servo quickly, or hitting something like a hard tumble?
The issues are from small capacity packs less then 650mah. For example, I was running 4s 300mah but my servos had issues as addressed in the thread but I swapped to 650mah 4s.
