Did the price of the Builder Kit go up?
I wasn't even intending on building an SCX10ii, but I don't care for the SCX10iii so I snagged a kit off of eBay at the old price.
Sweet nice find I haven't seen many recently but Ebay is my go too for pretty much all mine.
Sent from my SM-G975U using Tapatalk
Yes, it did go up $40, with no upgrades. The price doesn't really make it worth it to get anymore IMHO. I just got my 10ii a few months ago, and the quality of it could definitely be better. All four shocks have leaked at least a quarter of the oil it holds (performs decently though), the plastics used are very brittle and soft (especially the rod ends of the links and pivot balls; screws are very hard to screw in on the transmission casing), and the helical gears (in the axles) bind pretty bad to the point the motor pulses under quarter throttle. I will say, that Axial did do a good job of designing its layout, as it crawls very well, has a very low CG, the droop in the shock setting is pretty good, and the kit didn't have any serious issues being put together, but seriously, it's a fairly old platform, so making some adjustments to refine it would definitely help (especially with the helical gears).
Element's new Enduro Builder's Kit 2 is just $10 more (original kit same price) and has much better shocks, higher quality suspension links (with metal instead of plastic pivot balls on the 10ii; bent for higher clearance compared to the straight ones on the 10ii), tuneable overdrive (10ii only has 3 gear fixed), stronger and stiffer plastics, and overall a smoother drivetrain. Of course, the 10ii has more aftermarket parts, but the Element also has decent aftermarket support and requires way fewer upgrades.
https://www.amainhobbies.com/elemen...er-builders-kit-2-asc40114/p-qqqctqkqycqrqctz
Just my opinion, though.
If helical gears bind you might need some shims. Most often between pinion outer bearing and driveshaft. I am surprised how smooth shimmed Wraith 1.9 axles feel. My personal best 1st gen SCX 10 shimmed axle does not come close.
I have seen people complaining about the Enduro front axle design, so anyone interested might look into that. There is also the HPI Venture kit for example. Might get some crazy overdrive from transfer case flip or something.
Welcome to the Joe Biden economy. Now it's hitting where it hurts, RC !!! :lmao:
Let's Go Brandon!
