I've read right here on this forum (and others..) that the 14.4v DeWalt motor has a bearing supported armature. Well, it doesn't.
I dug into mine after getting tired of a screetching sound I could only eliminate by spraying a little WD-40 into the back of my motor. A little later, it would start screetching again though. Thinking it was just a bad motor, I was surprised when a couple weekends ago, my brother's DeWalt powered Summit was making the same sound. It was time to find the problem.
After removingthe brushes and prying off the end cap, I was surprised to see that the back of the armature is supported by a bronze bushing, not a bearing. And yup, it had a sloppy fit on the armature. Luckily, it measures 8mm x 5mm x 5mm. So I replaced it with two 8mm x 5mm x 2.5mm bearings, and problem solved. The motor is now silent, and turns very smoothly. If you don't have a local hobby store with bearings, you can order Traxxas part # TRA5114 and get a package of two bearings that will work.
Hopefully this helps anyone with the same screetching DeWalt motor problem.
