Descriptions Mamba Monster X: motors?
VikingCrawler
Wichita
What are the first numbers in the Mamba Monster X: motors?
1515-2200KV, 1512-2650KV, 1415-2400Kv, or 1406 - 4600Kv
I know the KV but I am not shure about the first number in the descriptions!
It is usually the O.D. (outside diameter) in millimeters (mm) and the length.
So if you take a Hobbywing 3660 4000kv motor its 36mm diameter and 60mm long. Or close to 1.4" around and 2.4" long if you can't visualize metric.
then people say 540 or 550 size that is also referring to the length and then castle says 1512 etc. I need to find a chart that has all of them on it to compare hang on.
No luck finding a working chart but in the Castle motors I believe that the first two numbers are the diameter of the Stator and second two numbers are the number of winds. Quote me on this but I *may* be wrong or completely right lol. If your buying a brushless motor just go off the size and kv don't worry about the windings since the kv will represent better. the kv represents at 1volt how fast the motor will spin. Don't forget to get one with the right sized shaft 4mm, 5mm etc. so your pinion gear fits.
