Der, die, das Üniversalmotorengerät U300
Gula
Subscribed Member
Here
Ja, Ich wollte immer einen Unimog, aber kann mir nur einen in 1/10 leisten.....,
Ooops wrong language..... , hold on Martin translate........ something about Ive always wanted one, unfortunately only being able to afford it in 1/10. Funny thing is Ive had this body close to 14 years now collecting dust. I just need some links and a transmission. I have a enduro chassis at the trailer that I plan on usinng
Not good,
this wide, so back to the drawing board, or spend the coin on the mst mpa portal axle, $90ish singular, but looks narrow AF, and descriprion on Amain saiz 194mm hex to hex.That's a good width
One of the axles was missing the portal housing, so I had to make a call to Amain and explain. Let's see what happens
Decided to just order the MST mpa portal axles regardless. I think they'll be here quick. That means ill also have to dig out the narrowest wheel hex, and "slw" adapters I can find in my stash of stuffs to keep the width as close to the wheel wells as I can.
