Danchee ridgerock 3s battery question.
r3mot3control
BC Canada
I’ve read that 3s batteries can be run safely in the ridgerock. The thing is what specs of battery. Could someone recommend a specific 3s to run in my danchee?
i would say what ever fits in the battery comparrment that rig dosent draw alot of juice so the batterys amp rating or c rating dosent matter to much
theres alot of resorces that explain c rating and mah ratings so i wont go i to that to much but
basicly any thing bigger than 1000mah and 30c should work fine that gives you 30 amps safely and that should be enuff for theose tiny motors
Thankyou kindly.
I had another question about those tiny motors. I’ve seen people replace them with some 37t motors, I’m assuming for more power? They also changed the esc to a 1080… which seems to require another radio… which just gets into a whole lot of complications I don’t want, lol.
Can a guy just swap out the motors to the 37t without the esc/radio shenanigans?
Thankyou kindly.
im not that smart off a a
check out the rock ridge thread in the redcat section more mods than you can shake it at
