This is my custom 6x6 build I am using for my college capstone project. The build started a year ago, and the project isn't due till May 2020. But I figured it'd take a while so I've been chipping away at it.
It started in SolidWorks and I designed the frame off of 3 AR60 axles. I went through 5 different frames before settling on one I liked. The 4th was actually better, but it required welding aluminum to make the frame all one solid piece. But since I can't weld aluminum, I made the design so I can make it with tools I have at home, a jigsaw and drill press.
The idea started when I converted my SCX10 to 6x6 but I didn't like how the pass through axle in the middle didn't allow the two rear axles to move fully independently of each other. Also it was too small.....
Parts I am using are mainly sourced from RC4WD. So far I have their aluminum links and rod ends. Wheels and tires will be here next week (only 4 for now). Next will be the AX2 2 speed transmission and another 1:1 transfer case (already have one) and of course I will get more punisher shafts. The shocks are Gmade 113mm shocks (only on the front now, I have random shocks on the rear till I get more of the Gmade shocks). I realize the drivetrain is somewhat busy, but it is what I came up with without raising the center of gravity to run a single straight axle back to the rear transfer case.
The frame rails are made from 3/4" x 1/8" 6061 T6 aluminum and the interior pieces will be made from 1/8" 5052 H3 aluminum since they require bending. I am currently using some 3D printed parts since I have yet to mess around with the bending part.
Finally for the electricals I will have Savox servos on all 3 axles (only 2 axles steer currently), two 2s lipos to make 4s, and the Mamba X 2280Kv combo.
Not sure about the body yet, I was thinking the Proline F250 body, but I'm not exactly sure what I'd do for the rear... Any suggestions are welcome!
Pictures *should* be attached, I've never posted pictures here so hopefully I'm doing it right.
Sent from my moto x4 using Tapatalk
