sherbs
In the last couple months I purchased a Cross RC GC4 and a HC4. Planning on them being easy terrain trail trucks. I am about 3/4 into the GC4 build and have only looked at the HC4. They are a high scale kit but do lack in a couple areas. Was very surprised that they use friction shocks similar to the G-Made jeep. The leaf springs were really a shocker, the main leaf is spring steel but all the other leafs are plastic. The chassis is done so I checked the travel, 2 of the plastic leafs broke. Solved the issue ordered Cross RC's leaf spring kits and RC4WD 65mm scale shocks. Being the plastic leafs are much thicker than the metal I had to also use RC4WD's axle blocks for the proper height. Anyone else do anything different? I will still have to do a upgrade on the HC4. Anyone have a 6 or 8 wheel Cross with the same friction shocks and plastic leafs?
