Northern Colorado Terrain Gallery
Started as a reference for good spots to crawl in Colorado. Maybe used to connect to others in the area to crawl. I am based in Ft. Collins so most areas will be within t he surrounding areas but want posts from all over Colorado. Detailed directions should be available if anyone wants to explore the areas.
Hope this evolves into a good list of spots to crawl spots. Post up.
The first spot I call Soldier Dam Gulch.
Just South of Soldier Dam at Horsetooth reservoir, there is a small parking lot and a trail down to the water. Drop over the small cliff edge and there you are. Multiple areas with terrain from simple to very technical. I've never been bothered. May be underwater if reservoir is more full than normal.
Link to map of Horsetooth reservoir
http://www.larimer.org/parks/horsetooth_map.htm
Oh yea, this is in "get togethers". I started this as a way to hopefully network with others in the area. I will start to post planned times to get out on the rocks. Post up if anyone in the area wants to get out.
