OSRC
I guess it was time to update anyway, it's been a while for this rig. Hope this helps Osteo
Overall side view, and a close up of the link area. The link set-up is basically the same as stock - basically I took the side plates and used them as a template and drilled out the holes on both sides. All of the holes in the chassis - upper links mounts, and upper shock mount areas are the same as stock - I did move the lower link holes up 1" in relation to everything else. Gave me more GC at the bottom, though moved the trans up into the chassis quite a bit. Also changed the geometry enough that I could no longer run the stock spring set-up even if I wanted to.
A look at the suspension set-up. The GMade shocks are awesome on this platform. It's not quite a droop set-up as the piston floats between a set of springs, and they can be set up in a long or short fashion. I like the short set-up...basically it gives about 1cm of uptravel to absorb bumps, and gobs of sprung downtravel to allow the axle to drop out/flex down. Took a little tuning, but it's spot on now. Very stable and predictable. Also a shot of the beefy KM steering upgrades. Very nice parts!
View from the top. By moving the trans mount up in relation to the rest of the chassis, it pushed the stock trans up quite a bit, so I replaced the trans with an axial trans as it was much shorter and allowed the battery to sit lower. Plus, the Axial trans has outputs much lower in relation to the stock trans and really helped the driveshaft angle. The battery mount is a leftover transmission mount with an integy battery tray bolted on. Works like a charm!
A little crowded in there, but it all fits. Running a sensored 17.5t BL set-up.
