First question regarding bullet connectors-
How much difference is there between a 3.5 mm and 4 mm bullet connector? This is for a trx4 tow rig ( HH Trailmaster Sport 27t/ HW 1080 ESC). I have the Protek 3.5 super gold connectors on hand already and I'd prefer using them but if the consensus is that a 4 mm super gold Protek connector will be safer/ better then I'll just go ahead and order those.
Second question regarding soldering together XT60 connectors-
I'm making an XT60 connector with dual JST connectors to run a fan and a direct power servo. Should I solder the XT connectors to one another directly or should I solder in two short lengths of [14/ 16 awg] wire between them?
This is one that I made already ( single JST) and I soldered a + and - wire between the two XT60 connectors but it's longer than ideal. I'd like to make another that is shorter but that would require me to solder the XT60's directly together. Just want to make sure that soldering them together directly with no wire will be sufficient.
Thanks in advance for any input/ advice.
