Coolest bodies for the TRX4
If you have lots of time on your hands you should do a blazer hardbody like mine. I’m not done yet but I’m close....
Did you have to move all the mini servos, esc, and receiver box to fit?
Was thinking the rc4wd blazer or lc70 Hardbody.... any input is appreciated[emoji108]
I am doing a LC70 and it’s quite a bit of work but will be worth it in the end. Now that spring is here I am probably putting it down till the fall when the weather turns bad again. If you aren’t going to run a full interior you can leave the electrics where they are. I am going to run small battery packs under the hood to move the weight up front. Front inner fenders and the rear shock towers are the 2 things that prevent the body from sitting down. I built my own rear towers and bed cage and cut the bed for the shocks (didn’t want cantilever and it fits the look I am going for. I also built my own front inner fenders. If you run a front battery it frees up some room to move electronics around. I am running a rear spool so that’s one less servo, a WP1080 esc fits under the dash in the firewall area... my goal is to run a knees up interior
For anyone wondering on another option for the trx4 , defender chassis....
... it’s the xtraspeed Jeep 313mm body. Fits on the chassis without cutting the rails. Just fits under[emoji108][emoji108]. Those are also the large 1.9 BFGs....
I just ordered a 1946 proline power wagon and since i already has this proline back half cage sitting around i thought ill try transforming my tactical for a more comp style built but waiting on the body to arrive first
Sent from my FRD-L14 using Tapatalk
Look forward to your choice of colour [emoji108][emoji108]
i have a traxxas trx4 defender what is the best mod i already have new bumpers winch lights anything like a motor or servo "thumbsup"
There is no one "Best" mod because everyone has different preferences. You need to spend time just reading the various threads and pick what mods appeal to you. It might also help to start your own thread in the TRX4 specific section and read what others have done to their rigs. That said, a very popular ESC upgrade is the HW1080 which actually works very well with the stock TRX4 Titan 21T 550 motor and a 9t pinion.
Scale Rigs Brand Specific Tech - Traxxas TRX-4 at RCCrawler.com
This is my current TRX-4 project - Proline K10 cab with a Vaterra cage.....
As you know, I've drooled over that one before lol. ^^^ I may go that route instead... so much lighter than a hard-body and just looks so good. I'd guess that your $ total comes in cheaper too. That Injora is over $70.
Walked in to Hobby Destination in Phoenix, walked out with a Yeti body for my Happy Bronco. Thanks guys, for being cool to me : ). Great shop.
Now about these fenders...
The TRX-4 is a standard-size 1.9" scale crawler, so you should be able to fit any 1.9" scale crawler body onto it.
Keep in mind that a hardbody will make it much easier to tip over, and you'll scratch the paint on a regular basis.
IF you have the Bronco,Chevy or Sport models the TRX-4 is a 12.3 inch wheelbase. The original Defender and Tacticals run a 12.8 inch wheelbase and will need shorter links. See the information from Traxxas.
https://m.traxxas.com/products/landing/trx-4/
Sent from my LG-H870DS using Tapatalk
Well I got the cage from Ebay, and that was a bargin but the lexan was about $65 as it was with the bed too, but that was the body I wanted - mind you everything is expensive by the time it hits the UK.
