ColinB
I'm running a brushless motor with a Tekin RS Pro. It has a drag brake, and that part is fine. However, crawlingdown hills, a tiny bit of throttle speeds up the truck way too much. On flat ground, the tiny bit of throttle is fine, and has good control. But downhill, it's like it coasts and speeds up much more than the bit of throttle.
I see the FOC type esc's would (should?) solve this. But I like to solve problems without buying more stuff if I can. Any suggestions?
The only trick I know is to steer a lot. With locked diffs, the binding causes a lot of drag. Drag brake is often too weak or too strong. Jamming reverse is just wrong. Lol.
Thanks for any info. Colin.
