A few months ago I got into RC crawlers, starting with a CMX chassis and a TBG repop of the old BoLink S10 Blazer body. The body fit the 252mm wheelbase pretty well. I do wish I had mounted it differently, the pegs are flimsy and ugly.
Right away I upgraded to bearings instead of the included bushings in the kit, and installed a 90T spur and 17t pinion.
For electrics I used a 27T HPI Saturn motor and SC-15WP ESC. I wish the ESC had fwd/rev mode instead of just fwd/brake/rev.
It is painted like a real S10 Blazer I had many years ago.
The first real excursion I found the stock tires to be adequate, but my old Blazer had wagon wheels and TSL SX tires. I bought some RC4WD wagon wheels and ProLine Swampers. The Swampers were 1.9 so I sliced a pie shape wedge out of them and super glued back together to fit the 1.5 wheels. The bead on the tires was no way going to work with the beadlock rings that came with the wheels so I just super glued the tires to the rim.
New tires = way better traction = twisted up drive shafts
This has been a recurring theme, I don't think it is as much a durability issue with the shafts as it is a lack of slipper clutch. When the tires get wedged into a crevice something has to give, and there is nothing in the drive line engineered to take that so the driveshafts twist. I've now broken two, even tried inserting a screw down the center of the shaft and it still twisted up and broke the yoke off.
