jboehler04
Goin used is a good idea. Like most hobbies getting started is the most expensive part. Are you wanting to do an open rear blazer or?
Goin used is a good idea. Are you wanting to do an open rear blazer or?
I had no issues with wheel clearance on my body its a Proline. Where did you read that?
That's not bad. Have you done a lil research on motors and their ratings? A 12t motor might not be the best for crawling will have good speed but not much torque. The lower the number on the t equals faster speed but lower torque the height the t rating the slower the speed the higher the torque. In example a 12t motor will be fast but lack torque a 55t motor will be slow but have good amount of torque. I, an most others, run a 35t motor and reduced my pinion on my motor down to a 16t so I slowed the truck down even more. Vs the stock 20t pinion. I would get the blazer body that you want and see how it fits. You might have to trim jus a lil bit but might not. Its gonna depend on what tires you run too. My pit bull tires tuck nice inside everything where as my Baja claws are taller and jus have to raise my body a lil bit on the body posts.
