#7 of 10, of the 1/10 Toyota lexan crawler fleet.
I chose this kit because I wanted to give MST a try, but also I get the nice J45C body to use for #10 of my collection. I told myself I wouldn't start another build until one is completely finished, but that became impossible in both wanting to modify/add parts and the eagerness of waiting for stuff (#6 Gen8 V2 4Runner isn't finished).
The '81 Hilux body, is slightly wider than the TF2 hard body (which this ladder rack is made for). But the fitment is pretty spot on otherwise for my satisfaction. The rack actually is what inspired me to start this build and make a work truck.
Some images of the assembly for whatever.
As you can see I went with Losi Mini T springs since I felt the MST springs are all firmer. Med up front and firm in rear. With the rack on, the body sits level. Now this is a bit more droop than I want to run on this, so I will do firm in the front and do a set of the stock springs in the rear. Whatever extra scale bits I add will determine the final spring setup.
Chassis complete. The Axial military wheels will be used for the #10 J45C build but these MST tires will be used on some Carisma Plastic beadlock steelies. Kinda want to stick with licensed scale tires for all my builds but I like this tread pattern.
Went ahead and grabbed the MST steel skid plate in attempts to help aid the to-be super top heavy truck. All my builds will be CMS so since this kit is axle mounted servo I also grabbed the CMS conversion kit.
Got the rack where I want it and cut slits in the bed. Because the rack is so heavy, I need to add bracing underneath so it's got some sort of structural integrity (idiot mounting steel on lexan). I've got an idea of how to go about it but if anyone has any examples feel free to share. I want the rack to be removable still.
You can see in the next image that the body is slightly larger than a Marlin, where the rack mount tabs are inset more than the bed floor width.
The front rails of the rack needed a bit of rounding off to clear the triangles of where the bed meets the cab.
CMS kit installed. Now since I didn't figure out a panhard setup for this, I left the 4 links in and spaced up the drag link a whopping 14mm. I haven't researched a proper solution yet but doing this plus spacing the servo back 8-9mm's gets it in line and with minimal bump steer. Might invest a whole 50 bucks into the aluminum knuckles and use aluminum spacers instead later down the road because I have a feeling there will be a ton of flex in this area.
