CFX-W J45C 322mm wheelbase stretch.
woodcox
Salt_city
Using the 5mm spacers on all the rear links included in the kit, adjusted it from 313mm wheel base to 322mm. Shock bolt moved to the rear hole.
When this truck tips back slowly it will sit and rest past vertical on the rear bed. Little throttle and it pulls the front end back down.
I'm jealous - love that body and rear caged-half!
More pics, please!
Body trimmed to fit. Some smaller tires with bead locks. Spare just sitting on the cage.
Cage off with room for a spare.
Capra shocks with red springs. Softer purple may be in order. It’s a little too tall.
Maybe you should try to move the lower shocks mounting to the lower link bolts (longer bolts that's all you need)
makes for a perfectly flat lower links, overall lower height (on mine at least) "thumbsup"
