I cut up some stainless steel sleeves for the links and I cut new lengths of all thread to the correct size.
I put one of the pieces of all thread in the sleeve and found it wasnt as tight of a gap as I had seen the other day. I have a feeling the first time I checked that there must have been a bur on the inside that made it feel like it was a snug fit.
Luckily I was able to design up and print some spacers to go inside the sleeve and make up the 1mm difference.
I'm not sure if I should worry about the fact that the sleeve is bigger than it should be and that I've fill this space with plastic. I'd love to hear folks opinions on the matter.
Links came out looking nice. the hardest part is cutting the sleeves to a precise length with a big old cut off saw. I chucked up the sleeves in a cordless drill and hit them with a scouring pad to get the SS look back.
Last thing with the links is to find a good way to bend the 2 rear upper links with the link all assembled (otherwise I dont think I'll be able to slide the sleeve on after bending). I may try to make a jig out of wood while I'm at work.
