Can't get full reverse with new Spektrum DX5C
TheJanitor
USA
So I upgraded the tx/rx in the RTR kit to the Spektrum DX5C kit. Everything works great except I only get about 25% reverse power. Throttle endpoints are 100%, and I don't know where to go from here. I calibrated the tx according to the spectrum manual. Is there another step to calibrate the esc?
Any other suggestions?
This is my first electric, as I've only ran Nitro's in the past. Thanks
I don’t have DX5C myself but perhaps give this a shot and see if you can adjust the reverse throttle rate... page 9 of the manual
RATES
Rates allow the driver to reduce the travel (0-100%) of the Steering, Throttle, or Braking with a trimmer button. The Override option allows drivers to select a different rate value (0-125%) while holding down the assigned trimmer button. This is especially helpful for oval racers that program minimal steering throw to desensitize steering during racing, but requires maximum steering angle to drive out of a crash or get turned around on the track.
To adjust Rate values:
1. Scroll to Steering and click the scroll wheel to select between Steering, Throttle or Brake. 2. Scroll Up or Down to adjust the Rate value. Click the scroll wheel to save the selection. 3. Set the Switch setting to On to enable Rates, select Inh to disable Rates.
4. Select an Override rate and switch.
5. Select the OTF (On-The-Fly) trimmer that will be used to adjust Rates On-The-Fly.
TIP: In order for the OVERRIDE to operate, you must assign it to a switch or trimmer. The default position for this function is inhibited
