Well, I figured I'd post this up, just to let anyone else who is curious about savox customer service, and how this is all playing out.
Here are a couple body off shots of my wraith. (The ESC holder isn't quite done yet, I'm going to make it look like a fuel cell when it's done, I also have a tonneau cover that needs some sanding which is really hard to do while on the road... Or hard to justify hand sanding when there's a nice disc/belt sander in my garage...) This is what I meant when I said that my soldering/craftsmanship wasn't the issue.
And here is a "copy and paste" of my conversation with savox, if anyone is interested. I said if they didn't want to help I was going to post it all over the forums, and as they've stopped replying to me I intend to uphold what I said. The first is at the bottom, and the last is just below this. If they reply to my last email, I'll post that up too, but seeing as they've stopped replying to me, I don't feel it's necessary to post that email.
Kyle,
Yes cutting the wire lead off is considered a modification, because the product is no longer as purchased means it has been modified. As such the warranty policy states any modification of any kind to the product is void of warranty.
We stand behind our products we distribute proudly thank you. These are the terms we uphold as a distributor and you agreed to when you purchased this product.
Joel
On Fri, Aug 29, 2014 at 10:11 AM, "Kyle" wrote:
So you won't stand behind your product at all, because the leads are shorter than what I purchased them at?
Good to know. I'll promptly be changing anything with your name on it to another brand that will stand behind their products. I'll make sure a copy of this email makes it to the forums I'm on as well. Thank you
On Aug 29, 2014, at 8:31 AM, Savox USA Support <customerservice@savoxusa.com> wrote:
Yeah unfortunately the wires does void you of warranty services. Sorry about that. You should have left the wires intact.
In case you are not aware companies like TQ Racing offers servo wire lead sets that are a bunch cheaper than 120$ to make custom lead projects, Here's a link to some of those lead sets I am referring to.
http://www.hobbyrecreationproducts.com/SearchResul...
On Thu, Aug 28, 2014 at 6:16 PM, "Kyle" wrote:
Hello,
I've recently purchased a 2270 servo for my rock crawler. I was looking for the most torque available from a servo under $150, and your product seemed to fit the bill. I installed it into my axial w raith, along with a dedicated castle creations 7.4v BEC powe r source. I only ran it for a few minutes, and noticed the steering stopped working, then I saw a puff of smoke come out from the front end of my crawler.
The case ended up getting so hot that it melted and shorted the power/ground wires just outside the case, and further diagnosis into it, it fried my BEC as well. I did cut what was left good of the wires off, to use on another crawler project I'm working on, and I ended up replacing the servo with another 2270, and another CC BEC, and everything works good now, but I'm out a $120 servo. Can you guys help me out at all, or am I stuck without any help because I cut off the wires?
