What links are you using for this particular rig? They look like parts for the scx24 platform, but I know those RC4WD axles is M2 hardware for the links. Did you just drill out the balls to size?
I’m looking for something that’s better compatible with those axles than what cheap shxt I’ve got right now.
Edit: I’m sorry, I totally forgot to mention how awesome this thing is going to be once you’re done with it. All your previous builds have been killer. Looking forward to the updates here.
Looks so good with the body on!"thumbsup" It's hard to believe it's a tiny scale rig! With all of the details, it looks much bigger than it really is!
The RC4WD axles have been a real headache,… But they look sooo good!
Nice work as always! I didn’t know about these axles. With those on, the speed of the rig will probably increase, as those are not axles with worm gears. I put fcx24 axles on my scx24, and they fit ok. But the links are twisted. Waiting for the driving videos.
"thumbsup" It does seem a little faster. It’ll will also roll if the drag break isn’t set.
B-MOW71 mentioned that it’s hard to believe that this is so tiny. I totally agree.
Thanks. It's amazing what you can learn on YT. Can't wait to see what BakeBeans does with his FJ.
It's coming along nicely!
I saw someone on Reddit replace the screws that secure the top of the body to the bottom with magnets which makes it easy to take the top off. Not sure what your plan is in the end but it might be something to consider. I am going to take mine apart so I can do that with my first build. Should be getting my replacement window for the rear tomorrow so it will be a good time to try it out!
This thing is so incredible. It looks like a 1/10 scale build, you can’t even tell it’s smaller.
I’m curious what you did for the front suspension mounting on the axle, since the factory location is not very compatible with coilovers.
