fyrstormer
This one surprised me. I found out about it a couple months ago, and I thought "hmm, it's old and it's not even close to TRF-grade like my XV-01s are, but it might be interesting to get a DF-03Ra kit for cheap just to compare to the XV-01." Famous last words.
I built the kit pretty quickly, as it's much simpler than the TRF-grade cars, with the only initial modifications being Tamiya hex-head screws (I have a pile of them left over from other builds), CVD axles, and TRF teflon shock pistons instead of the cheap nylon pistons that come with Tamiya's plastic shocks. At first, the lack of turnbuckles, flexible steering, awful Rally Block tires, wobbly plastic outdrives for the center driveshaft, and rear ball diff with plastic(!) thrust-plate adapters seemed to confirm my expectations that my XV-01s would blow this thing out of the water.
Then I actually drove it, and noticed an awful chattering coming from the drivetrain, and figured out it was actually rejecting the CVD axles I put in the rear! Since this is ultimately a converted buggy chassis, the rear axles are swept forward at a sharp angle to achieve a proper ~255mm wheelbase; because CVD axles have a dogbone joint at one end and a cardan joint at the other end, the difference in angular-velocity profiles between the two types of joints was making the rear wheels vibrate like crazy. This car couldn't even use fancy parts! Even more proof that I shouldn't expect much.
But the thing is, once I fixed the issue with the rear axles, it actually drove really nicely. It's not as oversteer-prone as my XV-01s, which makes it somewhat less exciting as a rally car, but it can powerslide if you give it a good shove, and when I took the thing on a 2.7-mile walk around a lake near a friend's house, I was impressed by how expertly it handled the bumpy walking trail and the acorn-strewn dirt off to the sides. (I was also impressed that the shaft-driven drivetrain is efficient enough that it actually ran over 3 miles, including loopbacks, on a single 5000mAh LiPo. At it's gearing-limited top speed of 25mph, it was actually pretty relaxing to shoot it up and down the paths to the entertainment of nearby children. The fact that it's a converted buggy chassis actually has a bunch of subtle benefits in handling uneven surfaces, which touring cars normally suck at, and despite having a comparable ride-height to my XV-01s it exhibits much less body-roll even with no swaybars installed.
So, I did my due-diligence and shopped around for parts that might improve the car's weaknesses, and now it looks like this:
The electronics are straightforward -- it's using the same Hitec HS-8775MG low-profile coreless servo that all my other touring cars use, the same Dynamite DYNS2210 60-amp brushed ESC that many of my vehicles use (it's cheap and effective, that's all I care about), and the same 12-turn Team Orion brushed motor with silver brushes and an endbell-mounted fan that two of my XV-01s and my MERV use. So there's nothing interesting in that regard, but...there's all that Tamiya-blue crack all over it, and that's worth talking about.
For starters, not all of the crack is blue, and not all of the blue is Tamiya. With my XV-01s I stuck to Tamiya parts exclusively, but Tamiya just doesn't make some of the necessary upgrades for the DF-03Ra. For instance, in the picture above, while the motor plate, heatsink bars (which are of questionable value, but...meh, why not), and center driveshaft are all Tamiya parts, the low-key black steel outdrives on the ends of the center driveshaft are actually made by a company called RC-Square. They eliminated the wobbly-driveshaft problem that the car had after I built it with the stock plastic outdrives. The blue servo-saver is made by Max Speed Technology and the blue endbell-cooling-fan posts are made by MuchMore Racing. Also, hidden under the spur-gear cover on the other side of the motor plate is a slipper clutch assembly for the DF-03 buggy, but it's running a 48-pitch 81-tooth spur gear from Team Associated. I had to replace the stock DF-03Ra spur-gear cover with the version for the DF-03 buggy to make room for the larger spur gear, but it was a direct fit.
The aluminum steering assembly is also made by RC-Square, and eliminates almost all of the flex from the steering system. It even has ball-bearing pivots for the center plate, like a Tamiya factory upgrade would; RC-Square definitely makes good upgrade parts. The blue pivot-balls are Tamiya, though the ones on the steering knuckles are actually leftovers from building a TB-04R kit; they have a 1mm spacer integrated into the base of the pivot-ball, which is just enough offset to minimize the bump-steer caused by the super-short steering links.
The shocks, of course, are Tamiya TRF shocks, which I now have on several vehicles in blue, black, gold, and purple (with assistance from some Max Speed Technology shock parts, which are interchangeable with TRF parts). On this car they're the normal blue color, but of course they work just as well no matter what they look like. Despite this being a rear-heavy vehicle, the leverage on the front A-arms is such that it needs stiffer suspension up front. The front shocks have the medium-stiffness tuning springs for the XV-01 and 60wt oil, whereas the rear shocks are still using the stock springs (which are the same as the softest tuning springs for the XV-01) and 45wt oil. Behind the shocks you can see the stock rear dogbones are still installed, sandwiched between O-rings in the stub axles and foam dots in the diff outdrives to keep the dogbones from rattling around or falling out. I'm not a big fan of dogbones, but this is one application where they are the only thing that works, and they do just fine.
So, what started out as a quick and dirty "hey, why not?" experiment turned into a car I plan to keep for a long time.
