BrazinScale RC Hi/Lo chassis
BrazinScaleRC
mishawaka
Brazin scale RC is proud to announce a new chassis design.
With the success of our first chassis, we set the bar even higher on this one.
For those of you who know that low center of gravity and forward weight bias are the best, then you have surely heard of toyzuki fabrications. Our new chassis design incorporates a direct bolt in mounting location for their forward motor mount.
our chassis offers a ton of adjust ability for shock and link placement as well as clearance between the axle and frame while keeping the skid and transmission low.
chassis is also available in 6x6 or 8x8/
This is meant to be a very versatile chassis from drifters, U4 Racers and SORRCA comp chassis
With versatility in mind there are 3 different versions of this chassis
A) Aluminum-for a light weight comp style crawler. weighs .114 lb.
B) Cold Rolled Steel-for the custom fabricators and tube chassis makers. Weighs .275 lb.
C) Stainless Steel- for our chassis slap and run kinda guys an gals. Weighs .285 lb.
D) G10 for super light weight setup 1.4oz per rail
We have been testing this chassis for 2 months and maybe even a few have seen it at some larger or local events and we are very pleased with its performance! This chassis will bolt directly onto a stock SCX10 chassis easily but some components such as the battery tray and cross members will need to be relocated due to the high clearance integrated shock hoops...so a mild to advanced builder skills are recommended.
Thanks to everyone apart of this exciting design and our customers for the continued support!
please pm for pricing, all other questions will be answered in this thread.
Current stock ready to ship
20 steel v1 chassis. This chassis does NOT have bolt on provisions for toyzuki forward motor mount, but can be drilled to accept.
10 steel v2 chassis. This DOES have provisions for toyzuki forward motor mount
Price is $55 shipped conus.
Day and night difference after installing these chassis rails. I experience very little to no torque twist and have a nice low cog. I recommend them to anyone looking for that next new hop up for their truck
Sent from my SM-G925P using Tapatalk
Time to step up your game!
Since the release Of the Hi/Low Chassis it has had great success out on the trail and in competition. Also with the new addition of an optional front motor mount that is made specifically for Toyzuki Fab FMM the evolution of this platform never stops.
We are very lucky to have been able to get our hands on the brand new Lightweight G10 Front Motor Mount from Toyzuki as well as they're smooth skid.
I think we can all stand back and appreciate this beauty!
We will be working on offering the chassis and mount/ Skid as a Kit to make it convenient but supplies are limited so please PM us for details...if we are out of the Mount and Skid then we will gladly get you hooked up with one from Toyzuki Fab.
Sent from the drivers seat of scx10
What wheelbase was this chassis intended for? I'm sitting at 13.5 right now and the damn axles hit my chassis front and rear, your large c notch should fix that if the length is correct. Thanks for any info!
i can get you an accurate measurement when i get home from work tonight, it is intended for a shorter wheelbase, i am running 12.5 and the rear axle sits just behind the rear arch with no issues.
13.5" wb on this rig. Wraith shocks full droop
12.3" wb on this one same suspension setup
I have zero contact on either rig between frame and axles or steering links.
Thanks guys!, I'm sitting at almost 14" with the new vanquish links so I would hit everywhere on this chassis. Looks great for anyone at standard scx length though!
Chassis is now available in G10 and carbon fiber!
We also stock the toyzuki forward motor mount and skid plate to make a full kit!
Here are a couple of 6x6 and a terrible pic of a 10x10 we did. We can also stretch the hoops to better suit big 2.2s
Finishing this bad boy up
Full Brazin and Toyzuki suite as well as a metalmasher yota body.
