Hi all!
I'm doing the unthinkable and rebuilding my upgraded Bomber RTR into a custom scale-focused crawler. The mod list is already pretty deep: JEC Racing shock towers, stainless TA's, and Anti-Roll Bar; VP Stage 1, CVD's, Diff gears (U/D rear), and Ti links; LURC FI Spools, OT axle shafts, and 2.2 wheels; Gmade XD Rock Shocks; and SSD driveshafts.
In emphasizing "Scale," I'm switching to smaller tires (4.75 OD, probably stretching 1.9 XL's on the 2.2 wheels), shortening the WB (it's already about 12mm shorter than stock) with JEC Twin Hammers stainless TA's, and a full-depth Wraith interior. I also have a full complement of aluminum body panels from Barndog, AMF, DMG, and Carter Fab that I'll be painting.
I've already built an all HR Wraith transmission with dig and mounted it on the stock skid with the DMG plate. I think the interior will fit even with the dig servo, though I don't have it yet to mock up. I'm planning on using Voodoobrew's dash panel to fit the Wraith interior. I still need to cut the receiver box down to clear the new spur/pinion configuration.
At this point, I'm still collecting parts. I still need suspension links, I ordered the TA's earlier today and I'll be waiting for those before taking measurements for the other link lengths for the desired wheelbase (probably around 350mm).
I'm only undecided about axles and powertrain, at this point. I'm pretty sure I want to go narrower and smaller than an AR60 pumpkin. I'm leaning towards AR44's with Wraith-splined brass tubes in XR10 width. My concern is for replacement axle shafts. Will they continue to be available? Fronts and rears are a bit hard to find, already. I'm also considering a metaphorical second mortgage and fitting the VP Currie portals. Then there are the SSD portals that are trickling out...and the Redcats.
Regarding powertrain, I'm not sure if I want to go brushless. If I do, it'll be a MX and a Revolver so I can go 4s and get a ton of power. If I go with VP portals, I'll most likely do this as there is more reduction in the axles. Brushed will be a MX (or BR-XL) and TorqueMaster Expert 550.
Then there's lights...front and rear running lights, brakelights, headlights, light bar, KOH lights, AND rocklights. These will be switchable from AUX channel(s).
I'm probably gonna do a winch too, but I'm already in a pretty big (and expensive) project. It's slowly coming together, though.
Stay tuned...let's see if I get it finished!
