The four-day holiday weekend, and some rare So-Cal rain, has led to my spending a lot of time in the garage working on these VS4-10 chassis. Now that Chassis #2 (3-gear trans, TRX-4 axles) is in a running state, I turned my attention to putting some axles under Chassis #1 (VFD Trans).
If I knew better, I probably wouldn't have even attempted this - but I had just got in a set of SSD Trail King Diamond Pro axles - Front and Rear. I built them up, and thought what the heck - the Trail King has an offset front axle, and it's very similar to an SCX-10 II - so maybe these would work with the VS4-10 chassis with VFD trans.
Installation went smoothly, up to a point...
I wanted to us a Traxxas Rx Box again, but I had to move it forward on the slider so it would clear the VS4-10 Pro-style battery tray. It barely clears when moved forward after filing off just a tad bit of the mounting bosses.
I also had to use spacers to raise the Rx box up so it would clear the bump where the outer slider rail bolts to the side tray.
I was eager to get this chassis finished, so I kind of forged ahead without really checking to see if there was going to be any clearance issues on the front-end. I used the included steering and panhard links from the VS4-10 Chassis Kit. All the rest of the links are from the Incision kit for SCX10-II 12.3" Wheelbase.
It became pretty apparent that I'd need to space the front upper link way, way over on the axle to allow it to clear the VFD spur gear cover. And the driveshaft interference with the skid was even worse than it was with the TRX-4 axles.
I really should have done some research before attempting to use SSD Trail King axles with the VFD. I would have seen right away that the Trail King is set up a little differently than a VS4-10 Pro.
Apparently, the front upper link on the SSD Trail King chassis is installed on the driver's side, and it runs parallel to and close to to the front driveshaft as it connects to the upper link mounts on top the front diff housing.
Oh well, another mistake made, and another lesson learned. No big deal. I will just use these SSD axles under another project - maybe a TRX10.2?
In the meantime, I think I'm going to go the tried-and-true route for axles under Chassis #1. VS4-10 D44 axles have been ordered.
