Body Leans to the Left
RCDad57
West Des Moines
The body on my Wraith leans to the left when I am driving it. It goes back to center when I stop. I am new to crawlers so I probably missed an adjustment when I was building this to prevent the lean. I would appreciate any help you would share.
Assuming all shocks and links are correct and not binding, you are dealing with torque twist.
Shock springs and links can be adjusted
Hang up and Drive
The driveline rotates in one direction and the chassis reacts in the other. Sway bars should help. I chose to ignore the issue on my Wraith. :)
or stiffen your shocks and out limiting straps on. wont help when crawling but still goood to do on the trails and stuff
If it doesn't help whats the point of doing it?
Mine did much the same, little chassis torque twist under power, unless it's causing the truck to fall over, you can ignore it.
If you want to try something, a simple no cost tuning is wind down the spring collar on the left front an extra turn or so to pre-load that corner a little, it'll sit a little cockeyed when stationary but will resist dipping over to the left when running.
