best springs and or shocks
cklanish88mj
ramey pa
right now i have stock set up with blue springs what is the best thing to do change to white or red springs or swap shocks and what size and brand
I run the losi White springs on my stock Axail shocks.I have the shocks internaly limited so the shorter and softer Losi springs fit.
I'm using Traxxas xxl shocks front and rear with 30wt oil,white Losi springs on the front,and 15wt oil,yellow losi springs on the rear.
My Losi shocks work great with the stock springs. People also have had good luck with the Traxxas big Bore aluminum shocks. If you are going to keep the stock shocks i would go super soft on the front and soft on the rear shocks.
Im running Losi's with the white springs. I use 30wt oil in the fronts and 50wt oil in the rear.
Im running big bores with the red springs and having good luck. I havent got my truck out of the house yet though but that is what I was recomended.
I have red (super soft) in front and white (soft) in the rear. I need to limit my travel, it has too much flex. Much better then the stock blue (super stiff) though.
Its really nice if you use the traxxas ultra shocks and do the ball end cap mod. No fuel tubing to mess with and it doesnt limit movement, and oh yah the ultra shocks are ultra cheap! I been running the Jato ultra shocks for almost a year and they havent leake a drop of oil and I got them for $18 shipped off ebay."thumbsup"
We have one truck running the stock shocks with soft springs in the rear and super soft in the front with 50w oil. The other truck has losi shocks with white springs and 35w oil. Both setups are working well.
