Best Shocks??
crawling-wallz
Canada
im looking for some fairly cheap shock for my hilux, that will flex alot more easier. With the stock shocks on my scx10 they flex, but then they rarely flex and i flip over :x . Plus when im on the course, i cant always climb up on the wooden suspended course to unflip my truck because it wont flex easy and it causes me to flip. I saw some proline shocks at my hobby store for 40 bucks? Are those good?? I will be using them for comp crawling and for trail crawling with my hilux body
its no problem if its going to rub, i can fix that, what i do need is some more flex and will i get that with the proline shocks??
Why not try softer springs first?
Ultimately a shock is a shock.
What you need is to try "tuning" them, and a softer spring is your best bet. As well as removing the bump stop.
Try a set of losi crawler White springs and remove the bump stops.If you want to buy new shocks I recogmend the Traxxas big bores,they work great and DON"T leak.
Yeah, I tuned my stock AX10 shocks to where I wanted them, one of the few remaining "stock" parts on my AX10. Tuned my SCX10 shocks too and now I am much happier with them.
If it doesn't leak, any shock can get it done.
I don't think the losi springs can fit on the stock scx shock properly. It's too big a coil.
But I agree that the traxxas big bore as being the best option. Especially for the price. The 8 pack is hard to beat.
i have ax10 shocks (120mm) and as long as you have weights in the wheels you are perfect! heres a pick of my rig with them! Always have traction to the ground..."thumbsup"
lots of fun!"thumbsup""thumbsup""thumbsup"
