XanderBolanos
Need to learn to format pics hoky headach
In both of my Gulf's I'm running surpass 2030's with Furitek lizards. The C10 (K10) is a 4500kv and the Jeep is a 6500kv. Both with 12t pinion gears. They both can still slow crawl pretty well. Not as crazy slow as with surpass 2204 1400kv but slow enough plus the wheel speed to jump up over things when needed. The 6500 kv was getting hot when using a lot of full throttle so added a heat sink.
Wow, those look great! What is the motor mount you use for these? Same as the smaller brushless mounts?
Oh, Tegu vs Lizard. Tegu is bigger. That alone makes a difference in some builds. Tegu can handle 3s. Some people must have that.
Tegu has a better BEC. Running 4WS? Maybe get the Tegu.
Thanx.. Motor mounts are from Shapeways (SCX24 Holmes Hobby 380 Revolver Low COG plate)
https://www.shapeways.com/product/4...yment-received&utm_content=3&option=195164488
I am still very happy with the 2030. As for which one I would recommend, it would be the 6500kv motor. The 4500kv has a lot more wheel speed than the 1400kv surpass but the 6500kv will let you do donuts. Something the 4500kv just comes short in doing. So if you are going for wheel speed but with the ability to slow crawl, then go for the 6500kv.Still happy with the Surpass 2030? If so, and you were going to buy again, which one would you choose?
Are there any alternatives to the hot racing pinions. I cant find them anywhere? Thanks
These are press on, so you need to put it in a press. I used my vise.
https://www.ebay.com/itm/294261961474
FYI, I got another 4500kv and have tried it with both a 12t and 15t pinion gear and I would still pick the 6500kv with a 12t pinion.
Verstuurd vanaf mijn SM-G975F met Tapatalk
