Ok so been running 3 channels 0 issues. Decided to try and use the forth channel for a winch.
Dx5 rugged has 4 switches around the wheel, 2 and a button near the trigger.
The button I set on ch3 for my lights, works fine.
Tried to set winch to switch above it. Winch worked great but sounds were that of it adjusting trim. Look at the screen it's maxing out or going negative on brake travel. The switch right above it does the same for throttle.
After spending 1.5 hours following the manual (which all the travel adjust settings to reassign buttons don't exist on the screen at all) resetting the TX twice, I was finally forced to put the winch control up by the wheel making it more or less totally useless because I can't steer and use it at the same time.
Now not supposed to be able to put 2 things on the same button on the radio, but well from the factory it's screwed up. Then no way of fixing it because the options that should be there are not.
Not to mention, what uneducated MORON puts the brake travel and throttle travel adjust on aux buttons by the trigger????
Sent from my SM-N975U using Tapatalk
