So, I am currently building a Defender 90 on an Axial frame, build in 1.9 scale rigs also.
Well anyways, since I upgraded the defender to all after market aluminum parts and heavy duty frame, I had enough axial parts to build a second truck.
I am not 100% sure which way I am going with the Defender 90 atm so this should be a nice distraction.
I got a unimog body and some portal axles to build it up.
So, here is how it sits now. I cut the cab off of the bed as I only need the cab for this build. I am also going to remove the roof, extend it for a four door open top fun crawler.
I shortened the frame in the rear, but am thinking of shortening it again in the rear by about an inch so that the frame rails end up just behind the shock towers.
Anyways, this is the humble beginnings, any thoughts, suggestions, comments, are appreciated.
Sent from my SM-J327T using Tapatalk
