Welcome to RCCrawler Forums.
I am trying to put Together an Ax10 transmition. How can I insert pin AX30162 into part AX 30197? It is tight! I have a whole shop of tools but no press to center the pin which locks a metal gear onto the shaft.
HUH?
It just slides a little tight, its not that hard. push it in with a pair of pliers if need be and you put the gear down over it. set it in the cradle of the bearing and when you put the case together over the shaft, it should be fine
