AR60/Wraith Servo/Truss/Link mount
Hey Erik, Just placed my order for my Build, Ultra4 Front wraith Truss for my New to me Ultra4 wheels7 chassis. Thank You "thumbsup"
Got my set on a pair of ar60 ultra 4 axles there amazing cant wait to get this build going.....my only ? Is what drag link do I need lol
Thanks for the order! I will have it out today for you.
The drag link length will depend on a couple of things. Best thing is to get a length and then you can either make one or I can make a TI link any length you need. Single TI rods are $15. Let me know if you need help.
Wow, just found this post. Found something I "need" for my Wraith now. I have the VP Stage 1 upgrade (C-Hubs, knuckles, lockouts), and the VP Steering Rod links. Running a Solar D722 servo.
Will the VP Titanium links work with your truss, or will I need a new steering linkage rod that goes from the servo to the knuckle?
Thanks in advance!
The tie rod should not change. I am pretty sure you will need to improvise or buy a new drag link (one that goes from the servo to knuckle) though.
Erik just found out that my axles not only have the ultra 4 setup on them but there also housing that you modified I got a awesome deal and you do some awesome work
Thanks Erik. Would you happen to have the drag links in stock?? Don't think I have anything that could cut the VP Ti drag link.
Thanks again!
I dont stock any links per se, but I custom make them all day. If you get me a length you need, I can usually have it out the same day or next.
I just received my rear ultra 4 style truss for my yeti. Is there any other more detailed instructions with pictures that i could look at to make sure that I have it together right?
Okay i got my truss all together but have noticed that the upper links on my yeti are too short now. Do you sell a set of titanium upper links or know the measurement off hand? I don't have any way of measuring at the moment. I was just about to install it when I noticed.
Yeah, your links will need to be a touch longer. You can install a longer rod end, like a Jato and it will be about perfect. If you want the correct size links, they are on my website. The rear uppers can be found on the same page as the UCfab trailing arms.
Thank you, the quality finish of the truss is beautiful and i will be placing an order for the uppers just as soon as I get my next paycheck. I will also be ordering a set of trailing arms. Will i need to get some revo rod ends and balls also?
Do you happen to know the typical length needed for the drag link? Curious so I can get a link ordered so I am not slowed down in putting my build together.
Wes
Should be close to 2.5" eye to eye.
If you need this link, I can make them for you.
quick question for you. Front outer right link sits outside of truss what size servo horn do you recommend. because at full turn left will hit head of outer link screw.
thanks
