antigacho
Hello from México
I want to start this threat the follow the building of my first RC Crawler
I already ordered all the parts that I thought were necessary, except paints, I haven't decided about the colors yet.
Inspired in the following photo I would like to modify the Tamiya Hilux body that I choose cutting the doors in half; I have no experience whit this kind of mods but I will do my best
The RC scene is very small in my city so the information in forums and RC parts reviews are very helpful in my case since they are my main source of information for this hobby.
I haven´t receive all the parts yet, but I want to start this post with a detailed list of the items that I ordered for this project:
KIT
1/10 SCX10 II Jeep Cherokee Rock Crawler 4WD Kit $328.55 AX90046
ELECTRONICS
Holmes Hobbies Holmes Hobbies TrailMaster BLE Pro $125.99 HO/210100006
Holmes Hobbies Puller Pro BL 540 Waterproof Sensored Crawler Motor (2700kV) $139.99 HHBPPBL540ST2700WP
Castle Creations BEC 2.0 Waterproof BEC Voltage Regulator (15 Amp) $39.99 CSE010-0153-00
Futaba R204GF-E S-FHSS High Voltage 4-Channel 2.4GHz Micro Receiver $46.99 FUTL7604
Savox SB-2290SG Black Edition Monster Torque Brushless Steel Gear Servo $159.99 SAV-SB-2290SG
Castle Creations B Link Bluetooth Adapter $49.95 CSE011-0135-00
ZOP Power 11.1V 4500mAh 45C 3S 1P Lipo Batería XT60 $30.33
ZOP Power 11.1V 6000mAh 45C 3S 1P Lipo Batería XT60 Plug (X1) $43.07
Powershift RC Technologies Battery DMS Dead Man Switch Unit PWR-097 $29.99
Small Switch Waterproof Cover 12V $4.75
Waterproof Mini Digital LED Volt Meter $2.28
HeyOK Performance The Lighting Controller $55.99 HEYTLC
Yeah Racing Ultra Bright LED Light Kit $6.69 YEA-LK-0001WT
Vanquish Products Rigid Industries 1" LED Light Bar $39.99 VPS06761
CNC LED Taillight Light Lamp $17.88
TIRES AND WHEELS
Pro-Line Hyrax 1.9" Rock Crawler Tires (2) (Predator) $57.98 PRO10128-03
Pro-Line 1.9" Dual Stage Rock Crawling Foam Inserts (2) $31.92 PRO6174-00
INJORA 4Pcs Aluminum Alloy 1.9 Beadlock Wheels rims $34.35
Rock Crawler Rubber Wheels Tire 1.9 Inch Wheel OD Tire 114mm Wheel Tyre For Axial SCX10 CC01 RC Wheel Rims $7.11
INJORA 2PCS Aluminum Alloy 12mm Wheel Hex Hub for 1/10 RC Crawler 1.9 Wheel Rim $4.39
INJORA 2PCS Aluminum Alloy 9mm Wheel Hex Hub for 1/10 RC Crawler 1.9 Wheel Rim $3.82
SSD RC Locking Hub Installation Tool $5.99 SSD00008
SSD RC Scale Hubs (Silver) x2 $19.98 SSD00253
BP Custom 1.9 Rock Ring Beadlock Rings $29.99
BODY
Tamiya Toyota Hilux Front Truck Body $16.00 TAM9335487
Tamiya Tamiya T Parts Front Windscreen Toyota Hilux High-Lift $8.35 TAMIYA/19225104
Tamiya Bruiser T Parts Tree Window Set $10.00 TAM9225139
RC4WD Mojave II Cab Back Panels & Grill Parts Tree (Primer Gray) $18.99 RC4ZB0074
RC Parts Metal Intake Cowl Grille Net Set & Lights for Hilux Tamiya Hill TF2 $26.58
Tamiya Toyota Hilux Front Grill W Parts Set $13.25 TAM9225105
2pcs RC Rubber Seats Chair For Axial Wraith 1/10 Scale Rock Crawler $9.01
RC4WD Trail Finder 2 Mojave II Rubber Mirrors $8.59 RC4ZB0082
Dinky RC "Yota" Interior w/Decals (Black) $28.99 DKY-SIBV3
Rubber Steering Wheel + Column with paddles for Tamiya Axial RC4WD RC 1/10 $6.99
JR fabworks truggy rear cage $140.00
Elastic Luggage Net w/ Hooks (yellow) $4.41
Tamiya L Panel Stay For Tamiya Hilux 58312/58397 (x2) $4.00 TAMIYA/14305048
INJORA 4PCS RC Car Shell Body Mount for SCX10 90046 $9.42
RC4WD Trail Finder 2 Tough Armor Front Tube Bumper w/Winch Mount $42.99 RC4ZS0765
RC4WD Axial SCX10 Universal Front Bumper Mounts $9.99 RC4ZS0987
4 LED Lights Kit 2 White 2 Red for 1/10 1/8 Traxxas HSP Redcat RC4WD Tamiya Axial SCX10 D90 HPI RC Car LED lamp $1.66
8 LED Light Kit 2 White 2 Red 4 Yellow for 1/10 1/8 Traxxas HSP Redcat RC4WD Tamiya Axial SCX10 D90 HPI RC Car LED Lamp $3.16
Seat Belt (red) $9.20
Metal Steering Wheel For Axial Wraith 1/10 RC $5.63
2 Pcs RC Car Fuel Tank & Mounts for RC Crawler $3.42
Plastic Fuel Cell Receiver Box for 1/10 Crawler $4.08
57*34*26mm Receiver Box Module Case for Crawler RC Car Decor Parts $8.34
Plastruct Plastic Weld Cement (2oz) $5.69 PLS00002
SHOCKS
Pro-Line PowerStroke Scaler Shocks (90mm-95mm) (x2) $94.98 PRO6060-00
Samix SCX10 Brass Shock Spring Cups (4) $11.99 SAMSCX2-4047L
Vanquish Products SCX10 II Shock Hoops (Silver) $64.99 VPS01861
4PCS/SET Aluminum Lower Shock Mount lift Kit For 1/10 RC Crawler Axial SCX10 $8.45
Lower Shock Mount Lift Kit (Black) $8.32
Team Associated Silicone Shock Oil (2oz) (30wt) $4.49 ASC5422
Team Losi Racing Silicone Shock Oil (4oz) (30wt) $6.99 TLR74023
Tamiya Toyota Hilux Lenses P Parts Set $9.75 TAM9115196
AXLES - STEERING
SSD RC SCX10 II Brass Weights (x2) $49.98 SSD00140
SSD RC SCX10 II Pro Aluminum Knuckles (Silver) $34.99 SSD00148
SSD RC SCX10 II AR44 Knuckle Bushing Set $2.99 SSD00182
SSD Pro Aluminum C Hubs Silver for Axial SCX10 II $26.09 SSD00149
Generic Aluminum 25T Servo Horn $5.46
ProTek RC 4mm Aluminum Short Clamping Servo Horn (Black) (25T) $12.99 PTK-7808-BK
SSD RC Double Bent Titanium Steering/Panhard Links (D60, SCX10, SCX10 II) $19.99 SSD00122
SSD RC SCX10 II Pro44 Titanium Steering Link Set $15.99 SSD00212
TRANSMISSION
Vanquish Products SCX10 II 2-Speed Transmission Motor Plate (Silver) $23.99 VPS08101
Boom Racing Helical Pineapple Transmission Gear Set $20.61 BR955016
Vanquish Products Atlas SCX10 II Aluminum Transfer Case (Silver) $29.99 VPS08104
SSD RC M4 Driveshaft Screw Pin (5) $1.99 SSD00237
SSD / SCX10 II Scale Steel Short Front Driveshaft $29.99 SSD00255
SSD / SCX10 II Scale Steel Long Rear Driveshaft $29.99 SSD00257
Axial 32.8x15.2x1mm Slipper Pad $9.98
Axial 32P Pinion Gear w/3mm Bore (14T) $5.99 AXI30725
Axial 32P Pinion Gear w/3mm Bore (15T) $5.99 AXI30726
EXTRA PARTS
Vanquish Products SCX10 II Lower Link/Shock Mounts (2) (Silver) $29.98 vps04467
Boom Racing AR44 Axle Diff Cover WSkid Plate (x2) $27.00 BR955013
SSD Pro Aluminum Rear Lockouts Black For Axial SCX10 II $20.00 SSD00146
Boom Racing BADASS Rod Ends M4 Nylon w/ Stainless Steel Pivot Ball $23.90 BRWM4RECOMBO
Axial Narrow 12mm Aluminum Hub Set w/Hardware (Black) (4) $6.99 AX30427
Samix SCX10 II 313mm High Clearance Titianium Suspension Link Kit (8) $49.99 SAMSCX2-5025HLS
INJORA Aluminum Alloy Front Bumper Mount Servo Stand $8.35
SCX10 Metal Front Beam Bracket Servo Relocation Bumper Mount Stange for 1/10 RC Crawler Car SCX10 II $8.35
Aluminum Servo Relocation & Bumper Mount For RC 1/10 AXIAL SCX10 II $14.40 SCX2024N
Aluminum Bottom Base Mount Middle Center Skid Plate $14.34
Samix Aluminum Center Gear Box Mount Set Gun Metal For Axial SCX10 II $16.60 SCX2-6046GM
Samix Aluminum Rear Chassis H-brace Black For Axial SCX10 $10.00 SCX-6027-BK
Boom Racing Axial SCX10 II Aluminium Front Frame Brace Gun Metal $12.95 BR955006
Metal Battery Esc Relocation Plate For Axial SCX10 II $12.99
Preacher 7 inch Action Figure Series 1 Cassidy by Neca $22 super expensive shipping $33
Axial Corbeau LG1 Seat Set $24.99
KIT
ELECTRONICS
TIRES AND WHEELS
BODY
SHOCKS
AXLES - STEERING
TRANSMISSION
EXTRA PARTS
