DrIsotope
Man is this thing a handful. I built mine from the kit form, and completed assembly as per the manual (ride height, oils, link positions, etc.) It is something else.
Torque twist like I've never experienced, WAYYYY too much brake for the stock suspension setup, and the roll steer... ohhhh, the roll steer. :shock:
I also managed to break an internal part in about half a pack of running. The pin that retains the small gear in the transfer case was kit correct
(I measured it) but seemed about 2mm too short for the slot in the gear-- so within about 10 minutes of smashing around, the truck made that
"my pinion has fallen off" noise. Nope. The pin turned the inside of that gear smooth.
But I think I like a project even more than I like a build, so I dove right in. Suspension is where I like to tinker, and as I was lucky enough to buy a sack
(I wanna say 30 pairs?) of Losi 8ight springs many moons ago on eBay for about $10, I either just convert trucks over to 8ight shocks, or make spring hats.
As a check showed 8ight shock sets going for $80-100, and this whole truck was $250, hats it is!
Overcompensating for the crawler-soft stock springs, I initially went way too stiff (2.3" grey in the front and 3.1" green in the rear) which had the truck
pogo-ing around like I had replaced the wheels with Superballs. Dropped two rates all around, 2.3" black in the front and 3.1" red in the rear. MUCH better.
Still have to mess with oil. They're significantly better, but now feel over-damped.
I've come to the conclusion that at this point in my life, I don't really like painting bodies. It's fiddly, it's time-consuming, and the bodies invariably end
up getting demolished. So I looked at what paints I still had on hand (some of the cans involved are pre-2010) grabbed two rolls of masking tape, and
went for a Frankenstrat-inspired, "it's supposed to look kinda messy" quick job. I'm completely okay with it. It ain't great, but it ain't terrible either.
Gonna be fun to see where this build ends up.
