Heroesneverquit
How durable is the gt3c when its dropped? I only ask as the wheel hanging off that small piece by itself seems like a breaking point.
So I've got this SCX10 ii. Completely stock parts except for the $6 metal steering arm.
I cut off the bump stops to gain some more travel.
The guy at the hobby shop said that he runs without springs because his is a dedicated crawler.
If I run without springs, what class would that be?
Also, I bought the pro line 85 Yota body. Planning on welding a rear cage together that will mount to the frame rails. Not permanently welded to the frame though.
Going to harden the body with a layer of fiberglass and a layer of Bondo. What class would this be?
Sent from my LG-H830 using Tapatalk
This will keep me busy for a while. I have a small 3D printer, today I printed a switch extension for the TRX4.
what kind of 3d printer do you have? I want one to re-do the battery bed for the TRX-4
You can get this on Amazon for the price of $200 save yourself $20I have a mono price mini. Version 1. https://www.monoprice.com/product?c_id=107&cp_id=10724&cs_id=1072403&p_id=15365&seq=1&format=2
It’s limited to how big you can make something, but you can’t beat the price.
Neal300 I have a mini Twin Hammer like you are talking about. I actually gutted the fake driver piece out and put netting along all the windows to keep debris out, and removed the stock battery tray and built one from sheet aluminum so it using the original hinge but instead of hanging over rear axle it hangs over the center of the truck right where the fake driver was. Doing this and removing the spare tire dramatically reduces center of gravity and have alot less roll overs at speed. I spent ALOT of time and $ on that little truck, I nick named mine NEWBRIGHT. It went pretty fast until I upgraded EVERYTHING but the shocks to aluminum for the suspension and all metal drive shafts. Slowed it down quite a bit. Burnt out the motor and put a new one in, within 5 minutes of the 1st test run with new motor it completely FRIED the ESC/Receiver. Now I'm waiting to upgrade all the electronics to ACTUAL hobby grade stuff. I have a new ESC and receiver from Xcelorin and a spectrum receiver but still need a mini servo and new motor/battery. I suggest not wasting time and money unless you plan on replacing ALL stock electronics. Be careful alot of the electronic kits are overpriced junk
Where can i find what a class 1,2 and 3 difference are etc ??where I could use help, mentoring is with the CLASS 1 truck, and Class 2.
I have an SCX10.2 for my Class 1 truck, cause it has a stock CMS. does it matter if I use 1.5 wheels or 1.9, I think the tires must be 4.19" or less?
I have my stock SCX10.1 for my class 2, because it has the Axle Mounted Servo.
what upgrades are a necessity for this class 2 truck, starting with a SCX10.1?
thank you
super bike mike
Funny that this is what it turned intoHELP THE NOOBS . Welp this crawler things deep and super interesting i have a 1/10 scale fill in the blank . But im totally into this and can only read so much on the internet becuase its exhausting and confuses me even more . What i would like is someone whos been winning comps with scratch built rigs that seems like a true hobbyist and doesn't mind sharing the love with me thanks ....
Sent from my SM-G955U using Tapatalk
