Adding some scale to the Ryft.
Timmahh
Mudville
Yes. I've heard it on Fakebook so it must be true.
Rock Racers are not Mid Motor rigs. lol
Ah well, whatchya gonna do?
I say F'm and make one anyway.
Well at least make it look like one anyways.
Picked up my Ryft in a trade. Been improving it some, and adding some more scale to it.
Diffs are locked but the front is still open, but have a locker for it.
Swapped out the Heart and Soul on it with a RX4/2300HD Tekin setup on a 15T p. Plenty of slow control (wont be doing MUCH rock Crawling) and good top speed still. bit faster than stock maybe. Installed, did the shift fork mod on both sides, removed guild post, and come up with a good and reliable shifting setup with a Reefs 99 Micro and Reefs Micro Horn so there is no problems with the shifting. Works like a champ now.
Added some lights about 10 days ago to see better as it starts getting darker earlier.
And over the last week I decided it need a bit more realism and vrom vrom.
I had this SSD Motor assembly from one of my TK kits so I decided it was time for it to get used.
a little assembly to get it positioned and figure out what to do to make it work and not be in the way of the sway bar etc, yet maintain use of the spur/pinion cover. I cut the original cover hoping to get it to fit, but that was a lost cause.
So I ordered a new cover in black and got to trimming the SSD Motor so it fit to the cover. Added some strategically placed bolts and nuts to secure the motor to the cover (washer and nut on the bolts under the valve covers holding the motor secure to the cover and the lower one in the oil pan also secures the motor assembly to the spur cover, and doubles as a mock oil drain plug for scale looks).
some test fitting
I like the way it's turning out. once I get the plug wires into place it will really give it a good look from the top as well.
And almost ready to install. going to made up some plug wires and glue them into place. May try to find a waterpump to bolt up. RC4WD has theirs but.... May just leave it as it considering.
ON to the plug wires and some tweaking and I'll get it installed.
