A.S.T.R. Scale Comp #5 - Sunday January 10th - Bad Lands
bmuzz1
San Tan Valley
A.S.T.R. Scale Comp #5 - January 10th - Bad Lands
This is our final pre-season comp, after this event you will not be able to switch rigs so hopefully you've all worked the bugs out or found the rig/set-up that works for you.
You will be able to make subtle changes such as links, electronics, etc. but the chassis and body must remain the same until the end of the 2016 season.
Comp #5 is at Bad Lands out toward Canyon Lake. Here is a link to directions from the 60 and Idaho. https://goo.gl/maps/R56P81xTc7C2
We will be running three classes, each class will run 3 courses with an 8 minute time limit each:
Class-1 “Street"
• Description - A street legal off-road vehicle that you would drive to work or the trail head and outfit like an expedition vehicle such as the Camel Trophy truck D90 rigs.
Class-2 “Trail”
• Description - A stock vehicle that has been modified to become a capable trail rated rig and is not necessarily street legal.
Class-3 “Modified”
• Description - An off-road vehicle that you would build from the ground up and might see in a TTC/KOH type competition.
If you are unsure which class your truck belongs in please take a look at the SORRCA rules for clarification.
http://www.rccrawler.com/forum/scale-comp-rules/521909-2015-scale-rules.html
For those that haven't been to a A.S.T.R. scale comp yet dues are $5 a comp or $25 a season due at sign in Sunday morning.
We will have a short drivers meeting @ 8:00 and will start the comp at 8:30am so please try to arrive early and have your scale points figured out in advance or they will not be added to your scores.
If you would like to help set courses I will be on site by 7am.
Also we could use some help judging so if you are able to help let me know, it will help move things along.
Thanks and look forward to seeing you all there
Brian Muzzy
