Ok, NOW, the chassis IS finished. While my clients are busy enjoying their evening, I had enough time to finish the rest of the chassis...the motor is installed into the transmission, the transmission/T-case is installed on the chassis, the servo is in place, and the shocks were filled & installed (tho, I'm not 100% happy with them). As I earlier, now I understand what others have been saying about the difficult in getting the mesh "just right" (or, "baby bear", as I call it). In the end, I had to disassemble/reassemble the transmission 7x...but, I did get it (and, yes, I realize I had initially attached the motor mounts backwards, on the wrong side of the motor plate, and on the wrong sides...but, I did correct my mistake before installing the motor/transmission/T-case.
In the step where I had built the transmission, I reported a slight "rough spot" when rotating the rear. Well, I can tell you that said "rough spot" is COMPLETELY gone...I can rotate the transmission all I want, and there's no longer any "rough spot". All that's left are the things I can't yet install - ESC, Rx, body, bumpers, wheels, and tires - because I don't have them (I probably have a spare Futaba Rx in one of my boxes...will check tomorrow).
Honestly, the shocks are actually fantastic...buttery-smooth, with really nice springs. The reason I'm "not happy" with them is probably my fault. I'm used to bleeder-style shocks, and traditional off-road emulsion shocks, but these are different, and I could use some help in understanding how they're supposed to be properly done. Here's what I did:
I filled them almost to the top, and then did my usual bleeding, by moving the shafts slowly up & down a few times, then leaving them in the 'up' position for 15-20 minutes. Next, I worked them up & down a few more times, then filled them to the top. Finally, I held the shaft in the fully-up position, and installed the cap (while also wiping excess oil than ran down the shock body). While I was screwing the cap, as I approached full tightness, I noticed that the shaft was being forced slightly down. Additionally, after the call was completely tight, I noticed that the shaft doesn't have full up/down movement...they fully extend, but, in the 'up' position, they stop short of being fully compressed by about 1/8-3/16". What am I doing wrong? Assistance is appreciated. Anyway, here's the completed chassis. In short, "I like".
~ More peace, love, laughter & kindness would make the world a MUCH better place
