*_* C.I.'s Lil' Nova Closed Cell Competition Ready 1.9 Dual Stage Foams *_*
I did tried those 4.50" Soft Outer in Front and Medium Outer in Rear for both 1.9 Pitbull and 1.9 Irok(new compound) with 1" wheels
well, I felt a littl bit stiff with 1.9 pitbull even I have Soft Outer in Front and Medium Outer in Rear, but don't know what u guys think?!! is that the way it should be?
Ran the set I bought. From you at ECC for the first time Saturday. They seem to be doing the job very nicely. I need a few more packs ran through them though. On one gate all the scale trucks needed to winch and I just drove it clean. I don't believe it would have made it with the old foams I had. A little nervous about getting them wet now that they are vented. Will be testing that out soon.
Wes
Thanks for the info Eddy."thumbsup"
Did you get the video links I sent ??????
I did, thank you for sending them. That is a cool FOFFer you got"thumbsup"
Have tried narrowing the outer foam? The outer foams are over sized on purpose. In general, the heavier the truck, the more outer you want to run. Or if you are someone that will play a lot in the water or mud, you want the foam oversized to hold up longer. Thin outer foams break down quickly, especially in water and mud applications. That is why I discontinued the original 1.9 dual stage foam line.
So with that said, what does your truck actually weigh?
The Pit Bulls are soft. The 4.50 should be plenty for them once the outer is tuned for the weight of your truck. Not mention, the foams will break in for at least 5 - 10 battery packs. The older they get, the more comfortable they feel.
The IROKS are a different story. Which compound do you have? Which tire is it exactly? How much does this truck weigh? I have not been impressed with this tire in either compound whether modified or not. I still run them because of looks, but it ain't for performance. I also run a single stage over sized closed cell foam I shaped for the tire.
Wes
That's good to hear Wes"thumbsup". Would you please post your trucks set up so others can know what is working for you.
I have a Jeep SCX10 based rig, which is right around 8lbs. My tires are 1.9 Baja Claws, which have the inner bead trimmed and a few of the lugs siped. The tires are mounted backwards from what most run, but we have found they grip better that way. The foams are the new closed cell, medium in the front and firm in the rear. The only trimming I did was to the front inner. Since I have lead weight in the rim I took off most of the little rounded part. I hope to get a few more packs thru them soon. I am thinking once they wear in I will be right on the money.
Wes
An old pic, but gives an better idea about my truck.
thanks for ur info buddy :mrgreen:
well, here are some info from two different 1.9 scaler....
my buddy's truck is about 7.25lb total include 1.9 custom wheels(the one I bought from u a couple weeks ago) + 1.9 pitbull with closed cell soft outer in front and Medium Outer in Rear,
my truck is about 8.55lb total include 1.9 MSD wheels + 1.9 Irok(X2 SS compound which is softer version) with closed cell soft outer in front and Medium Outer in Rear as well.
they are 1" wheels, so I think I am good with inner foam now, but would u give me some suggestions for the outer foam?
do I need to get some different size for outer foam?
Just placed an order. I had a problem with the captcha. Every time i entered the
captcha it was incorrect. Please check your site a verify my order went thru. Thanks for an incredible product."thumbsup"
Extremely happy with the turnaround guys! Ordered a custom width set of Lil Nova inners on Sunday. Got them today! Thank you! I mixed the short inner with the outer from my midsized Lil Nova set and stuffed them in my Pitbulls. I haven't tested the combo yet, but they feel awesome. Perfect sidewall bulge and they're stable.
Thank you, CI!
-B
Thank you for your business and I got you all taken care of.
Thank you, CI!
-B
Awesome!!! Thank you for the great feedback"thumbsup"
I answered you in a PM, but basically you need to narrow the outer foam to 1.75" width. Stock outer foams are 2.25" width which is a lot of foam to stuff in a 1.9 tire. That extra outer foam is needed if you have a super heavy scaler or plan to do a lot of water or mud driving.
If your 1.9 Lil' Nova dual stage closed cell foams seem to firm in your scale tires, narrow the outer. Simple sharp scissors will cut through it easily. You will be surprised how much softer removing just a 1/4" from the width of the outer will make.
I have a scx10 dingo, running mayhem slammerz 1.9 and the stock ripsaw tires. It weighs in just under 6 lbs. Which of these foams would you recommend? The stock foams are to soft for me. Thanks
recently put the 4.75 foams in a set of cut and shut 2.2 to 1.9 proline tsls. 12lb rig, med fronts, firm rears.
when i first got them in and the beadlocks put together i thought they were waaaay too stiff. but that was comparing them to normal foams. once on the trail i was going places wraiths with the big 2.2 iroks were going.
darn nice foams. i dig how they fill out the sidewalls and give the tire shape. very stable on sidehills. higher speed stuff is drastically better as well.
very nice product. cant wait to get the double dueces put in my iroks. "thumbsup"
I want to bring my 5.40" 2.2 Proline TSL SX's back to life and have them compete against everyone with the Irok's. 8lb rig.
Tell me what to order! :ror:
Great product, picked up a set for my 1.9 Yota Truggy. When I was installing them thought they would be to stiff however after running them a couple time they work great. Thanks
Thank you for your feedback. The foams definitely have a break in period. They start to settle in after 8 - 10 battery packs or so. Please post up your set up so we can compile information about what is working.
The rig is a Modified Scx10 with custom round rod truggy bed with Tamiya Toyota cab, linked front and rear with pro-line scaler shocks right now weight on the rig is 7.5 lbs..<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
Running RC4wd Rok Lok's with inner rib ground off and mounted to Mayhem Eng. 1.9 beadlocks using the medium height foams uncut at this point. Front rims have 3oz. of weight each and using the soft outer foams, rear rims have 2oz. of weight and am using the medium outer foams.<o:p></o:p>
This is not a comp rig, just a trail truck however it does get around pretty good. Compared to memory foam I was using before this set up it now side hills 50% better if not more, turning with the weight of the truck on the front end is night and day do to more side wall support allowing the tire to hold it shape more consistently. Steep vertical climbs have improved and I believe will improve more once the foam breaks in. <o:p></o:p>
