89redranger
After beating on my MRC Pro for about a year now and bending/breaking a lot of the factory components, I've decided to skip Spring cleaning and dive head-first into a rebuild of my favorite mini-crawler.
I have found that I wanted to change a lot of things about the Pro model purely to suit my own driving needs.
Thus far I've built a centered servo plate for my 645MG (for now), shorter upper front links to facilitate the BTA steering, longer rear upper links,all new lowers with bent rears top and bottom, converted the front knuckle and king-pin hardware, and replaced a lot of the cheesy factory hardware with stainless where possible, and anything but those damn button-heads everywhere else. I'll sacrifice a little hang-up to avoid the constantly wrecked factory junk.
I'm also running the factory Pro alloy shocks in the rear with a single-hole piston in the right and a double-hole on the left, and 1/2" of pen spring to suck it into droop. The front is mini late model shocks with about 3/8" of pen spring, Pro alloy shock caps screwed on with the eyelets cut off the late model shocks, MRC rod ends, 3-hole pistons, and 35WT all around.
All links were built with 3/16" aluminum tube with 3mm threaded rod through the center and a combination of factory and Traxxas rod ends. The servo plate is .065" aluminum plate
Anyway, these are mockup pics with no electronics and a broken chassis plate. Have questions please ask.
By the way, the tube is about 3.8" tall. I'm right at 3.75" directly under the center of the tire at max flex. Not bad considering how low it sits. With the Blue claws I have 1 7/8" under the belly. With the Rovers I'm putting on narrowed wheels I'll be at around 2"-2 1/8" under the skid. Perfect for the crawlin I do. Nice thing is, using 2 of my originals and 2 of the late model shocks left me two more of each shock so I could rebuild an identically valved set without the limiting springs for courses with more break-overs and ledges. with the shock towers down like they are now, I can also mount the body about 3/8" below stock, as well as how much lower the chassis still sits below stock. I think the body is over an inch lower than stock now.
Check the adapter I made that allows me to run shortened upper links so I could run BTA steering and keep the 4-link!!!
