6x6 motor options
allancorrigan
Charlottetown
I am in the process of building a axial scx-10 6x6. I am curious about the whole dual motor setup. I am using a sidewinder 3 and a tekin 35t motor right now. I was curious if I can run 2 tekin 35t motors wired together and only have 2 leads going to the esc. And would this setup be better for my 6x6 or should I just leave the first setup. Any help would be great.
I have the stock axles and stock trans with metal gears installed.
I would just keep one motor and gear down at the pinion. No need for two motors. Or swap to a 45t motor.
If you want crazy low end torque, wait until another batch of these come out. I have used a version of this motor on a 15lb rig and a 30lbs 8x8 rig with no torque issues, geared correctly on 3s lipo.
Holmes Hobbies LLC
