magic2002
3d printed Wild Willy 4x4(updated with video)
A while back I had the idea to make a Wild Willy 4x4. I know I am not the first with this idea, and there are some exelent ones here on this forum, but I wanted to share my version anyway.
So far I have build and scrapped a aluminium sidepanel chassis that was not working as i wanted it. And now I am building version 3 of my 3d printed chassis based on losi mrc axles. Version 2 was running great, but needed some minor improvements to make it better.
here is a video of the unboxing of version 1
<iframe src="http://www.youtube.com/embed/RcKUkmk72lE" allowfullscreen="" frameborder="0" height="315" width="560"></iframe>
here is a video of version 2
<iframe src="http://www.youtube.com/embed/rhXrGPX1n4E" allowfullscreen="" frameborder="0" height="315" width="560"></iframe>
here is a video of a strength test of version 1 of the chassis
<iframe src="http://www.youtube.com/embed/7xu7PsnhLW0" allowfullscreen="" frameborder="0" height="315" width="560"></iframe>
For those of you who want to build one, this will be a step by step "manual" with some explanation, but you will need to figure some stuff out by yourself as well...::
Here is what you will need:
The list of parts:
- axles and complete drivetrain of a losi mrc
- a micro servo
- threaded bar, M3 and M4
- aluminum tube, that just fits over the M3 threaded bar.
- brass tube, that just fits over the M4 threaded bar, with an outside diameter of 6mm
- a 3d printed chassis, with 3-link arms (Wild Willy chassis for losi mrc by magic2002 on Shapeways)
- some tools.
- drill bits, 1,5mm 2,5mm 3,5mm and 6mm
- a Tamiya Wild Willy body.
Of the 3 chassis I had printed so far there were 2 with some "print lines" on them. The 3d printed prints in layers of 0,15mm and depending on how the model is printed sometimes these layers show on sides of the model.
So I start with sanding these print lines down. I do not sand them all down, on the motor mount I think they give the chassis some personality.
After sanding the holes need to be drilled. All holes are marked or already in the model, but not at the right size because of printing tolerances. Here is a picture of where the different holes need to go and what size they need to be.
and this is a picture of the rear 3-link arm(it is the longest of the 2), the holes in the front one are the same.
Get your wild Willy body out, place it over the chassis to mark where the holes for the bodyclips should come. There is a little room on the body mounts to place the body somewhat higher, Then you will need to also mark and drill holes underneath the body. On the lowest position no holes underneath are necessary. I use the 1,5 mm drill bit for the holes in the body mounts.
With the chassis in front of you it is easy to spot where the holes should be, and one can drill all holes from the outside of the chassis going in.
After the holes are drilled 4 pieces of brass tubing need to be cut to a length of 9,5 mm. they will be used as a bushing in the 3-link arms
after cutting press them in the arms.
To attach the 3-link arms to the chassis 2 pieces of M4 threaded bar is used, cut down to 73mm. Screw the threaded bar in the 3,5mm hole, and when it just comes out on the inside slip the appropriate arm(front at the front and rear arm on the rear) over the bar before screwing the entire bar from one side to the other. There is no need to use a tap in the chassis, the material is some sort of nylon, and the threaded bar makes the inside thread like on a nylon insert locknut.
It should look like this when finished :
After this step, I paint my chassis. As this is not a painting pictorial, there are no pictures of that. The paint used is Tamiya acrylic paint. It seems to work very well with the 3d printed material, almost soaks it up like a sponge.
While paint is drying I start with some preparations to be able to mount everything to the chassis when painting is done.
To make room for the support bar at the front of the chassis(this bar is on the real chassis as well)
the servo needs to go back a bit. I used the original mrc servo mounting plate and modified it. I cut out a 12mm corner, so that it still mounts to the axle with 2 screws. here is a picture of how it looks... (notice the dirt on my axle... That is from when it was mounted on version 2 of the chassis, I left it on because i like the weathered look...8) )
I used M3 threaded bar for the steering arm.
That's it for today, stay tuned for more...
:mrgreen:
The list of parts:
- a micro servo
- some tools.
:mrgreen:
