John, please make sure to consider all the options while writing the new rule down.... http://www.rccrawler.com/forum/axial-ax-10-scorpion/526093-tgs-shafty.html
There Is also a torsion chassis 2.2S the DAHU........
Hello !
Is my shafty good for the new rules ?
the motor is fixed on the chassis and it's a rigid junction to the front axle.
www.rccrawler-france.com: Forum Dedié aux Crawler et Scales Radio-Commandé en France, Conseils, Astuces pour Créations Chassis Complet, News, Galeries Photos, Liens Utiles • Afficher le sujet - Le dahu sportsman losi
There may also be a need for a definition of what is an "shafty axle". In other words..... What if a chassis mounted motor and gear up transmission is placed between two Berg/XR /Bully axles. The multi gear axles differ from standard ring and pinion Shafty axles. Dan's truck at World's worked very well but if allowed would impact the class. I have been asked if I would come up with an adapter to make it work..... But I consider it detrimental to the class and against the intended competitors.
Because of the difficulty in defining this with so many custom possibilities, we will either have to define how chassis can be attached to the axle to eliminate possibility of fully rigid mount, or we will make a "judges call" where any style vehicle that is built to transmit motor reaction torque directly to an axle can be deemed illegal at the event.
True..... I had that thought too but wasn't sure if "two gears" was correct either! Lol
what about wording like was used to define bodiless ...... (my memories shot but) something where it said the cab had to be separate from the supporting chassis. You had to be able to remove the cab portion and still have the chassis remain supported.
Sorry that's vague but maybe something saying transmission must be connected to the chassis in a way that it becomes useless when the axles are detached from the chassis .... ?? Or something pertaining to how the axles are attached to the chassis like you mentioned.
I seen no wording about cab/bodyless like described above in the usrcca rules.
Sorry just need to know if I've missed something...
That's what I'm getting at, but with a torsion chassis you can make a chassis/ tranny/ axle sandwich that would effectively lock the chassis and tranny to the axle yet still have independent components that would pass "chassis mounted tranny" wording.
The point of shafty was a gateway to pro. Some bad ass builders worked within the rules to develop rigs that no ordinary shafty can compete with. See 2014 Worlds. Anyone without one of these is bringing a knife to a gun fight this year. Clarify the rules to keep sporty the introductory class. More classes are not good for crawling. We need consistent classes with rig specs that vendors can target. We need another XR10 like product. If the core class rigs (pro and sporty) change specs or overall design then vendors may bow out.
Guys should always push the boundaries of design within class rules. That's when the rules need to be tuned to adhere to the intention of the class.
